s13/s14 subframe conversion bushings << Previous thread | Next thread >>
kaspar
Mon Jun 04 2012, 06:28pm
Registered Member #782
same as stance or spl...but im sure like with most things,you can put a good twist on it
Wed Jun 13 2012, 06:33pm
has already been looked at spoken of and malled over. think this was tossed asside because of the subframe risers that kinda mostly do the same thing as swapping the sub frame without swapping the sub frame
NismoPlsr
Fri Jun 15 2012, 01:52pm
Registered Member #988
Standard subframe riser will improve the roll center but people swap to s14 for less anti-squat.
Stance swap bushings are already $125, though.
Fri Jun 15 2012, 08:24pm
for less anti squat ???? so for more squat is what your saying ???
NismoPlsr
Tue Jun 19 2012, 01:19am
If you want to say that, yes but s14 subframe still has some anti-squat.
kaspar
Tue Jun 19 2012, 02:49am
already have stance,intallation was a cunt,no directions,or marking lines like spl
Tue Jun 19 2012, 02:45pm
NismoPlsr wrote ...
dude you make no sence what so ever... either way im sure dan will pipe in, we have all ben over it and found the correction in geometry with the subframe risers and the addition to the modded knucles give you much better geometry without increasing track in the rear. s13's are notorious for under stear as it is. widening the rear would only make that worse, regardless of geometry.
ps you want squat, weight transfer creates traction and more traction = more controle.
[ Edited Tue Jun 19 2012, 02:47pm ]
Tue Jun 19 2012, 07:41pm
of course a spring swap is the easiest way to adjust squat.
Tue Jun 19 2012, 10:17pm
i would have to agree
kaspar
Tue Jun 19 2012, 11:55pm
as for the issue with the rear,run s14 flca.......issue solved,and a couple * of extra camber,for more pointless shit
