FC rx7 Full Steering angle and Suspension parts set is released UPDATE p.5 << Previous thread | Next thread >>
slowgxl
Fri Jan 25 2013, 01:16am
Registered Member #966
soo when are those solid diff mounts coming out?
Fri Jan 25 2013, 07:50pm
between 2-13 and 2-20 on the (round) solid subframe and diff riser, more time until the front 2 stud 3 hole solid mount is available.
slowgxl
Sun Jan 27 2013, 05:56am
Ok cool can't wait! I'm glad someone is making a solid front diff mount for the FC's. Keep up the good work man!
Mon Jan 28 2013, 07:08pm
will do. we are making everything you could want for this cars suspension
slowgxl
Sun Feb 24 2013, 05:12am
hey man saw that you posted the new parts...pumped to order them on my next pay check. also i forgot to ask...are you guys making outer tie rods too? i see you guys made rack spacers.
Mon Feb 25 2013, 08:44pm
The front end angle parts are made to work with the OEM tie rod and tie rod end because the set will include an aggressive rack spacer.
slowgxl
Wed Feb 27 2013, 12:51am
Ah okay....So a lot of people switch to special bearing outer tie rods. Saying that it will help get a little more angle and last longer then stock. What is your take on this? Is it worth switching over or is OEM fine.
Wed Feb 27 2013, 01:33am
last longer...typically not because the aftermarket ones are the high misalignment type which has a large surface area to gather dirt and then they wear themselves out faster versus the OEM ones that are lubricated and closed to the elements with a boot which lasts longer.
slowgxl
Fri Mar 01 2013, 05:37am
okay cool...thanks for the info Dan.
Sat May 04 2013, 01:06am
A few new prototypes we are testing now,
Toe Eliminator Bushing
Trailing Arm Rear Upper Bushing
Trailing Arm Front Bushing spherical bearing conversion
[ Edited Sat May 04 2013, 01:11am ]
