spacedog
Fri Apr 20 2007, 02:17AM
Registered Member #47
can you reply with the specs for the coilovers u offer for the FC3S?
Thank U!
Fri Apr 20 2007, 03:20AM
The most unique feature on the MAX FC coilovers is the ability to adjust camber AND caster at the same time with the special top plate. It used to be that OG FC drifters like Drift Samurai would have to drill 4 additional holes in there shock tower to get some caster adjustment but our special top plate essentially does the job for you. The standard spring rate is 10f 8r. and like all MAX coilovers you can dump the car super low even on smaller diameter wheels thanks to the full tap threads giving independant ride height and spring pre load. Pillow ball upper mounts front AND rear are standard as well as urethane lowers. Check out the prototype top plate pic. Time will be about 6 weeks.
spacedog
Fri Apr 20 2007, 04:19AM
Thx for the quick reply DC Dan! Ill soon be picking up a set as a good friend of mine Peyvand "DoriftoArab" has highly recommended them to me.
I'm under the impression that ur coilover units are serviceable. What would be the cost of doing so?
I'd also like to know if you made a unit like this http://www.racingbeat.com/resultset.asp?PartNumber=14008 to adjust rear camber for FC's.
Thanx again!
[ Edited Fri Apr 20 2007, 04:23AM ]
Parts Shop Max
Fri Apr 20 2007, 10:40AM
Registered Member #1
日本からアメリカに送る部品が有りますので 一緒に送りましょうか?
Fri Apr 20 2007, 08:01PM
spacedog wrote ...
Thanx again!
Serviceable, yes they are however we understand that people need there cars and need to save time and money so heres how we smoke the competition when it comes to service. We'll give you an ENTIRE replacement damper for the price the other guys charge to revalve a damper. http://www.tein.com/overhaul.html Which is $125ea. And there almost always in stock, ready to go when you need them WITHOUT having to ship both ways.
No we dont currently make any arms for Mazdas. In the future we could make them ...sexier.
Fri Apr 20 2007, 08:04PM
Parts Shop Max wrote ...
No problem!
Fri Sep 07 2007, 06:11AM
FC coilovers set sail to the USA in 10 days.
DoriftoArab
Fri Sep 07 2007, 07:11AM
Registered Member #25
spacedog sold his FC and bought an 07 honda CBR600RR daniel should be happy tho
danegerous
Wed Sep 12 2007, 08:39PM
Registered Member #52
Hey Dan how many sets did you order? Trying to see how long I have to get rid of the JIC's
BigWave
Wed Sep 12 2007, 11:14PM
more than enough
