Genesis Super Angle Kit - In limited stock now $1150
Complete front end set including:
~ FLCA, Camber and Track Width adjustable, DOM tube, Adjustable Forged rod end with forged clamping rod end receiver, clamping jam nut, teflon lined spherical bearing, high misalignment spacers and silicone dust covers ~ Tension rod, caster adjustable with proprietary parts listed above ~ Tie rod end, CrMo Teflon lined with aluminum turnbuckle, connects to OEM inner tie rod. ~ Roll center adjusted, Single steering pivot super angle knuckle bracket, double shear mounting, bolt on but does require cutting ~ Double heim joint adjustable sway bar link ~ OEM sway bar adapter bracket (sway bar no longer attaches to coil over) ~ Adjustable steering angle bump stop ~ All high grade hardware needed for install is included ~ Gold Zinc Coating (iridescent)
