Fri May 22 2009, 03:18am
I know URAS sells something similar but my new idea is to move the bracket up so the rack can come farther forward than the exsisting design.
This should eliminate overcentering and bumpsteer as well as steering feel and response.
The NEW design eccentric bushing set shown on the left, standard bushing in the center, and new rack position shown on right (without e-bushing for clarity). Even though these are shown flat, they sit in there at an angle. CAD is for S14 version.
Thoughts?
[ Edited Fri May 22 2009, 03:20am ]
Marcus
Fri May 22 2009, 05:31am
Registered Member #439
off topic, but what program do you use for CAD?
is that solidworks?
[ Edited Fri May 22 2009, 05:31am ]
Fri May 22 2009, 05:18pm
I use sketchup
red_rabbit86
Mon May 25 2009, 08:10am
Registered Member #102
could you post pics of the uras ones or mabe a good article or us non tech ppl
irax
Mon May 25 2009, 08:47pm
i like wehre this is going
Tue May 26 2009, 09:12pm
I dont see any pix on line, but you can see them in any Drift tengoku mag
red_rabbit86
Wed May 27 2009, 08:37am
kewl i just got last mo issue i will take a look at them. so with these bushing it pushes the steering rack out towards the front of the car?
Thu May 28 2009, 07:06pm
forward and up
red_rabbit86
Fri May 29 2009, 11:20am
o i see how that could eliminate bump steer kewl. good idea. what type of material would you be using?
Zenkikid
Fri May 29 2009, 04:23pm
Registered Member #35
When will these be out dan? I plan on swapping my motor out later on this summer and I wanna replace my rack bushings while im down there
