We are jigging up for some rear knuckles. Planned features: ~100% machined steel - no casting components ~drop spindle ~pillowball replacements for all bushings ~improved strength ~independent hydrobrake caliper bracket
as some of you know I destroyed my OEM rear knuckle which is some motivation for this, that and I think its a badass part to make.
the carnage
the Jig in process
The limiting factor of how much we can raise the spindle to drop the car seems to be the interaction between the RUCA arm and the axle boot. Our current RUCA arm is upswept already especially designed for lowered cars so if you even try to do a drop spindle on someone elses RUCA your pretty much f@cked.
we disconnected the coilover and jacked up the wheel all the way to take a look at the most extreme clearance situation:
And then we put it back to a normal suspension compression and measured again
It seems like 3/4" drop spindle is the happy medium because it looks like half an inch is totally safe and 1 inch is the max. with the half inch subframe risers its already a big difference so this should be a great mod for suspension performance on extra low cars.
If we wanted to take it farther we would have to sweep the arm up on the RUCA more or get a custom slim boot for the axle, but I'm betting as is its going to make a huge difference without going any farther.
I guess im just that manly. There was not any crash. There has been a couple of articles in DT about broken rear knuckles in the same place.
a few of questions about those:
1 they look to be thinner where the hub bolts on, and thinner material than stock around the bushing 2 they use bushings not pillowballs right? 3 What distance to they raise the hub 4 it looks like the stock relationship between the top and bottom arms was not maintained, the coilover mount and the LCA were moved down in addition to the hub moving up 5 How much are they
2. yea they use bushings on the hub end 3. i think the front is raised 45mm and 50mm rear 5. dont know about price, dont think a price has been released yet.
They look like they are working pretty damn well. iirc He's run them in his 2JZ S15 for 2 seasons now
So you're moving the hub up in the knuckle so you raise the roll center?
I really like the idea of a separate caliper bracket for a hydro e-brake. However, you should also make extensions for this for people who upgrade rotor size.
The concept that is presented in the video (1:07), as pointed out on the front spindle is sound and simple, "by moving the spindle up without changing any of these geometry points..." (you lower the car without fu@king up the geometry plain and simple.) However it appears that the same simple logic may not be used in the creation of their rear knuckle because the lower arm appears moved down in addition to the spindle moving up. Please correct me if im wrong.
I dont think the rear axle is raised up 50mm, it looks to be around 30mm no more than 35mm. Maybe the car is lowered by 50mm because some of that is from dropping the coilover/lca mount and some is moving the hub up but from my observations above you would be hard pressed to move the axle and its boot up more than 25mm before it hits our arm, and to my knowledge no ones RUCA is upswept like ours so im thinking its not possible to move the axle up said 50mm and maintain clearance with conventional axle boots and RUCA.
The relationship between the rear arms at the knuckle attachment points should probably not be moved or it will change the path the wheel dives under suspension travel.
