humbly request your services for AE86 << Previous thread | Next thread >>
Fri Feb 04 2011, 04:42AM
lu_e think you could post the pic on here that you posted on club 4ag? the one of the torn shock tower, just to give everyone an idea as to why you guys dont like the coil over system..
Lu_e
Fri Feb 04 2011, 06:51PM
Registered Member #938
Whoa there I never posted the described picture.
I'm pretty sure you're talking about what ryceboy_124 posted; http://forums.club4ag.com/zerothread?id=85402&postid=814317#814317
& I don't like the looks of that bolt? but what do I know... on second thought how is that damper control coming through? did it just pop through during the accident or was there a HOLE DRILLED? this would make a HUGE difference. I'm just not sure what's going on there.
http://im1.shutterfly.com/media/47a1df23b3127ccefc50d2a0b5e300000030O00AauGbFm0auGQPbz4E/cC/f%3D0/ps%3D50/r%3D0/rx%3D550/ry%3D400/
I'm not exactly totally opposed to the design... more not sure
[ Edited Fri Feb 04 2011, 06:56PM ]
Sat Feb 05 2011, 02:24AM
ah i see my bad thought it was you that posted it. never the less i dont under stand it as well. kinda why i said on the other thread it looked like something other than the coilover that caused it to tear in the place it did..
Fri Feb 11 2011, 03:44AM
hey has anyone seen the blitz zzr coilovers for the ae86 ? just wondering what they look like since the only photo i can find is a representative photo and not an actual one....
Mon Feb 14 2011, 08:19PM
there is a rectangular hole cut there to make the coilover top fit?
Lu_e
Wed Feb 16 2011, 02:11AM
^ Something like that.
Sounds ridiculous to me.
[ Edited Wed Feb 16 2011, 02:12AM ]
Wed Feb 16 2011, 05:57AM
im lost. oh well.
Lu_e
Sat Feb 26 2011, 07:43AM
Thu Dec 15 2011, 01:38AM
Super AE86 update!
We have finished the design and testing of the AE86 coilovers!
~ 8 and 6 KG springs F/R
~ True coil over damper rear conversion
~ Weld on connection to front spindle
~ Weld in rear upper mounts w/ Spherical bearing housing
~ Stock arrives in March
~ Pre-order your Competition version pictured below for just $1000 today!
~ Also available in PRO version with comp features plus CASTER adjustable front upper mount, spherical bearing rear lower mount and Super Light Linear Springs for $1350
~ More AE86 Multilink, Chassis and Steering parts coming soon = )
I would like to thank Ryan Literal for being our ginuea pig...
...and also for handling track testing duty.
Camber adjustable top plate (pictured without damper adjuster installed)
Front Coilovers welded to OEM spindle:
In the back we changed the car to a true coil-over-damper instead of using the OEM style separated spring and damper.
This means you will have the ultimate selection of springs available to you and you will have more ride height adjustability.
Rear Coilovers installed:
We took some Ground Control/Eibach/AGX coil over dampers off this car and the spacer they used for the top of the spring killed 3 inches of shock travel. This is our solution:
These Spring top hats completely separate the pillowball motion from the spring action, and with our cylindrical design, the damper body can actually pass through and above the spring giving unrestricted stroke.
Dont blame us for the inconsistent roll cage welds, that was there already!
Next pic is the rear upper mount and pillowball housing welded into the car (damper adjuster not installed)
This gets rid of the old rubber bushing upper mounts that rob the feel and response of the rear suspension.
This is our solution for the rear lower mount, the car came to us with the OEM tab bent down, and we fortified it with a triangle gusset against the 4 link bracket.
At this cars ride height, the upper rods on the 4 link were binding so we recommend moving the mount up through the rear seat floor to correct the rods angle, improve roll center and prevent binding.
The diff was laying on the bump stop that was mounted between the 2 holes in the bare space in this pic:
So to gain rear suspension travel, we trimmed the rubber stop with an air saw.
Now we are ready for ride hight and handling bliss!
With the new found traction, Ryan can throw his hachi-roku around harder than ever without ever lifting off the throttle!
Good job keeping up with Ross Petty!
[ Edited Mon Nov 23 2015, 09:07PM ]
SD9K
Thu Dec 15 2011, 08:35AM
Registered Member #27
these coilovers were absolutely amazing to drive with. i really can't believe how much better they are then the T3 ones i had before. huge thanks to the great guys here at parts shop max for the excellent work!! Do not waste your money on anything else
