Rack / Inner tie rod offset forward spacers to prevent over centering at lock << Previous thread | Next thread >>
Thu Aug 25 2011, 02:25am
Developed for the 350Z angle kit ... but can be used on s-chassis too.
[ Edited Thu Aug 25 2011, 03:33am ]
TravyPoo
Thu Aug 25 2011, 03:04pm
Registered Member #890
very cool. when will they be available? price?
Thu Aug 25 2011, 03:25pm
I'll post up when I know
Mon Aug 29 2011, 04:26am
so this over rides the idea of offset rack bushings yes ??. also can you share the solution you guys found on this from his rack end expliding after the hit with ugh charels? just currious what the actual problem was. thanks dan and these parts look sexy in copper
Tue Aug 30 2011, 08:14pm
offset rack bushings are better because these see a lot of torque.
i think the problem was first running over the 6" tall gator back track curb opposite of original track direction
then dirt dropping
then hitting someone after it was already loose
wisdomination
Wed Aug 31 2011, 04:29am
Registered Member #653
How much millimeters do these things move the inner tie rods?
Debatig on whether I should cut and weld my rack mounting points or get these...
Wed Aug 31 2011, 03:38pm
ah got ya thanks for the insight man.
Fri Sep 02 2011, 01:08am
36mm forward
Thu Dec 15 2011, 09:00pm
price has been announced $100/pair shipped for early adopters, arrives the end of January. Reserve yours today by paypaling $ to the USA contact email address
Tue Dec 30 2014, 01:13am
To check your rack for compatibility with our tie rod off setter , hold up the picture below to the rack as viewed from the side with the inner tie rods removed. S14-15 and late 13 is like the Z33, early S13 is different.
[ Edited Tue Dec 30 2014, 01:18am ]
