rwdanthony
Sat Jan 21 2012, 12:38am
Registered Member #1196
87 supra, 7mgte, r154, sport package (lsd, no tems, abs) 61k miles.
Full build up for general fun and drifting.
I started this build around jan '11, so most of this is back tracking.
engine:
block has been decked and honed
head has been decked, lapped, and given new valve stem seals
HKS 1.2mm headgasket
ARP studs
ACL main, rod, thrust bearings
NPR piston rings
57 trim ct26 Polished compressor housing, ceramic coated turbine housing
FMIC & aluminum piping
Synapse Synchronic BOV
Synapse anti stall kit
NGK ignition wires
Denso MDL560P injectors
EV1 injector pigtails
Denso 195130-1270 280lph fuel pump
lexus 1uzfe maf
yada, yada, yada
EV1 pigtails being soldered in and fuel upgrades
got the original mounts welded by martin, dont see the point in buying solid ones when i could just do this.
currently on hold:
rebuilt the transmission before it went in got a bunch of nice goodies while i was at it.
action stage 3 6 puck clutch disk & pressure plate
full length SS clutch line
Maxgrip lsd kit
4.30 lsd
rebuilt my work equips and ended up with
18x10.5-12
18x11.5-26
225/40/18 f
255/35/18 r
suspension components:
part shop max competition coilovers
battle version rear camber arms
battle version rear traction arms
shortened toe arms
SuperNow outer tie rod ends & steering rack spacers
Power Slot rotors front & rear
EBC red suff brake pads
dropped the rear end so doing a couple of things
solid rear subframe risers
shaved unnecessary brackets and studs, not sure if i want/need to brace it.
lowness
exterior:
s2 authentic rear fenders
part shop max hood risers
jdm kouki tail lights
jdm sidemarkers
euro signals
kouki side mirrors
kouki front bumper
martin working his magic
[ Edited Tue Feb 28 2012, 04:04am ]
Supraclean
Sat Jan 21 2012, 06:08am
Registered Member #1127
Looks good man, love the wheels/stance direction your going.
deolio
Sat Jan 21 2012, 09:20am
Registered Member #1048
rad!
Fish
Sat Jan 21 2012, 01:52pm
Registered Member #986
Beast!
Sat Jan 21 2012, 07:57pm
dude knoch that sub frame where the axle is hitting and just weld some plate around it so it dont tear. cant beleive that this thing is as low as pbm coils can go, never seen that before ever and for that i apluad you, thing needs like some bn stlye kit and would win so hard its retarded. ps is marty going to do some kako knucles for ya and any rolling shots ?
rwdanthony
Sat Jan 21 2012, 09:53pm
Supraclean wrote ...
deolio wrote ...
rad!
Fish wrote ...
Beast!
thank you, thank you, thank you.
Hollywood wrote ...
yeah i was thinking about doing that. notching it and then welded a plate to cover the hole. but i figured its useless since im already rasing the subframe about 15mm which is more than enough to clear, even if bottomed out. i wish BN made shit for this car. hell, atleast someone. current aero for this car is a joke. funny you ask about the kako knuckles. i just got an extra pair to be worked on:
other than that, not much new from yesterday and today... drilled another set of holes in my stock sway bars for adjustability, probably only be putting the rear as stiffer since it understeers as it is for me. then dropped off the rear subframe with the sway bars for powdercoating.
finished the LSD
energy suspension sway bar bushings. NOTE* energy suspensions database for my car is incorrect.
factory sway bar diameters:
F - 27.2mm
R - 21mm
energy suspension database/catalog:
F - 27mm (8.5133)
R - 23mm (8.5134)
Though the front is .2mm small, it still works. only issued i encountered with it is that the overall height was 2.5mm too tall so i trimmed the bottom. rears i had to return and buy the universal kit, product number 9.5125.
i bought these from: http://www.energysuspensionparts.com/
The whole hassle with their database being wrong and for me to be the one losing the money on shipping is really unsatisfactory customer service, i think.
[ Edited Sat Jan 21 2012, 09:55pm ]
o.g.darkdrifter
Sun Jan 22 2012, 12:38am
Registered Member #580
Fitment looks tough! Good to see someone putting in work on one of these. 7Mgte.... sketchy haha. But the R154 looks good..... sell it to me please.
gaki no tsukai
Sun Jan 22 2012, 06:59pm
Registered Member #594
Sick build man. how was it building your lsd? Do you reccomend ther wier max grip kit? Im am looking to build mines before the season starts this year
rwdanthony
Sun Jan 22 2012, 10:23pm
o.g.darkdrifter wrote ...
Been running the 7m pretty hard for about 8 months now and its been fine. knock on wood* i still need to get it tuned.
gaki no tsukai wrote ...
installation was pretty straight forward. so far i just got the unit back together. On the market right now for some oil, ill let you know how it is after i get my car back together. still waiting on some subframe risers and then i can put the rear end back up so i can drive this thing.
[ Edited Tue Jan 24 2012, 04:52am ]
Parts Shop Max
Sun Jan 22 2012, 11:06pm
Cool!!
