o.g.darkdrifter
Mon Mar 26 2012, 10:52am
Registered Member #580
My apartment management gets upset every time I put my car up on jack stands haha.
rwdanthony
Fri Mar 30 2012, 05:21am
Registered Member #1196
oh i feel you haha, alot of my buddies have to deal with that.
rwdanthony
Fri Mar 30 2012, 05:24am
My lovely girlfriend bought me this brake master cylinder brace for my birthday! <3 I'm going to have a solid brake pedal with this.
this finally showed up! this means I should be able to fire her up again this weekend!
[ Edited Fri Mar 30 2012, 05:25am ]
rwdanthony
Fri Mar 30 2012, 11:34pm
First start after 5 months: cabin
http://www.youtube.com/watch?v=EEFF2mLFVho&feature=youtu.be
[ Edited Fri Mar 30 2012, 11:38pm ]
rwdanthony
Tue Apr 03 2012, 03:45am
finally abs delete is complete!
these finally came as well, fresh from the container!
smells like japan!
because monster!
rwdanthony
Wed Apr 04 2012, 05:23am
Abra...
Kadabra..
Alakazam!
Deedilus
Wed Apr 04 2012, 06:43am
Registered Member #1090
This car is dildos.
Super well done man, thing is absolutely GORGEOUS!
Thu Apr 05 2012, 12:47am
this pic is hot, going to use it in the products section till you get paint.
Supraclean
Fri Apr 06 2012, 05:13am
Registered Member #1127
Looks good man, solid parts, sharp looking car. Badass weight reduction on battery. I aprrove!
rwdanthony
Tue Apr 10 2012, 02:48am
thanks guys! not much updates, been busy with my cs rc car haha
ive been missing my sc300, so i made this to satisfy my feelings.
anyway, about my 1:1 car, i finished all the wiring for under my seat, with the exception of my speaker wires.
then these were finally made: a70 supra solid subframe riser bushings!
installation would have been easy if my subframe wasnt powdercoated, i had to sand the holes and lube it to push in the bushings. it was still snug so i didnt use epoxy. for a regular finished subframe, just epoxy it, and slide it in!
i got everything back together and test drove the car, boy does the solid rear end make a worlds difference, i didnt attach my rear sway bar back on yet, but i was able to get loose petty easily. i still need to adjust my ride height, put back on the rear sway bar, get an alignment, and fix my s2 fenders to accommodate the suspension geometry change.
[ Edited Tue Apr 10 2012, 02:59am ]
