Had these for several months now and wondering why the rear strut tubes are longer than before? The gen before these I could lower 'til I scrape the ground. Right now my spring is just snugged and tube is all the way in the rear lower bracket.
Wondering if the set I got were an accident or if they were replaced for longer tubes. If replaced, why it was not stated in the products info.
I don't mind buying a pair of shorter ones for the rear, but just thought low and stiff is what these were all about.
there was a change at some point to that specificaiton.
If you want to double check the length of the part to see if it is correct, just tell us the measurements and I will check it against the current specification.
