Genesis bolt on super angle kit << Previous thread | Next thread >>
El_StiG
Tue Oct 01 2013, 12:26PM
Registered Member #3573
Dan. Any more info on Genesis bolt on Super Angle kit? I just saw Insane Innovations LLC is working on a kit for the car already.
https://www.facebook.com/InsaneInnovationsAZ?directed_target_id=10808857959
I'm dying to get my hands on this.
Tue Oct 01 2013, 12:57PM
Thanks for the heads up on the competition. Should be soon. I'll post the actual date when I have it.
ozonegc
Mon Oct 28 2013, 05:37PM
Registered Member #2986
Hey Dan hows the new revised version of the coilovers going? I think i saw someone post on the forums saying december?
Fri Nov 01 2013, 05:24PM
coil overs are here in comp version now
El_StiG
Mon Mar 03 2014, 11:41PM
Anymore Updates Dan? I saw that the New ARK drift car has another Pre Production set. Are they still not ready for release?
Thu Mar 06 2014, 05:12PM
Im going to release some limited qty.
El_StiG
Thu Mar 06 2014, 10:47PM
Really? How soon? =)
Fri Mar 07 2014, 07:53PM
Genesis Super Angle Kit - In limited stock now $1150
Complete front end set including:
~ FLCA, Camber and Track Width adjustable, DOM tube, Adjustable Forged rod end with forged clamping rod end receiver, clamping jam nut, teflon lined spherical bearing, high misalignment spacers and silicone dust covers
~ Tension rod, caster adjustable with proprietary parts listed above
~ Tie rod end, CrMo Teflon lined with aluminum turnbuckle, connects to OEM inner tie rod.
~ Roll center adjusted, Single steering pivot super angle knuckle bracket, double shear mounting, bolt on but does require cutting
~ Double heim joint adjustable sway bar link
~ OEM sway bar adapter bracket (sway bar no longer attaches to coil over)
~ Adjustable steering angle bump stop
~ All high grade hardware needed for install is included
~ Gold Zinc Coating (iridescent)
Fri Mar 07 2014, 08:35PM
D-mertz
El_StiG
Fri Mar 07 2014, 08:56PM
you sir are my hero! Thank you!
