Spline Drive Racing Nuts - Locking key problem! << Previous thread | Next thread >>
Influx
Tue Aug 27 2013, 02:22am
Registered Member #742
Hi PSM,
I need HELP!! on the MAX SDRN lock key that cracked & unable to remove or tighten!
Tested both method to tighten & loosen, I have a set tighten & loosen with impact wrench while the other set strictly only breaker bar, both ended up similar result!
Any recommendation on tightening torque? Possible for impact wrench or just breaker bar! There's no problem with the lug nuts just the lock key socket!
Could it be the lock key too thin? Any replacement with thicker lock key socket?
Thanks for the time!
Wed Aug 28 2013, 05:46pm
It is thin - which is required by some wheels. You cant use an impact wrench. Theres no need to over tighten past 75 ft. lb. otherwise it damages the nit finish and the key. Anyhow this is cheap to replace. Email us.
