i can't wait to go try my car on the track ... the coilover are realy siff ... i guess it will be easier to loose traction and to drift ... i will start with that and see how it goes !!!
fucked : - toe arm - traction arm - rear knuckle - axle - Rpf1 17x10 - rear over fender - metal under the over too
( if my toe arm would not broke my wheel wound of bien total , im happy with the result and with the PBM product ... thats why i bought some new one the replace the broken one ) i reused part from my toe arm to rebuilt my traction arm , bought a new set of toe arm and change the rest that was fuck !!!
... car is now back on track with a complet new look (full D-Max type#3 whit D1 front and rear over fenders) !!! did a compresion test at the same time ... first time since my rebuilt 150psi all around perfect condition ... i did a great job building my engine
the car is under the knife for the past week now !!! its at my sponsor shop up here in MTL ... AV Fab striping the car completly , make a cage , tube front , single turbo conversion , downpipe
the car got there and strip from its bodykit avec interior in around 2 hours
then to remove the OEM sound deadening we used dry ice ...
let it on the area you want to remove the sound deadening for around 10 to 15min depending on how big it is ! on top of the dry ice i was puting a garbage bag juste to keep de air from hiting on the dry ice ... when the time as come switch the ice to the next area you want to work and let it sit for an other 15min ... by the time it freeze you will have time to remove the sound deadening from the last spot
just hit it with an hammer and it shoud come out ... if the hammer is not enough juste use a pry bar ou screewdriver and pry it up abit
for your info 25lbs bag of dry ice was 32$ at Praxair here in MTL
after that all the sound deadening was out ... we started on the cage here is a couple pics of the cage inside the car . im realy happy with the result ... the cage is realy tite and i have almost the same vision when in the driver seat !!
(on the last pic here you can see Mitch32 on the top right that is helping out)
we had trouble with our notcher ... so we decided to start on the tube front and wait for monday to finish the cage !! the fisrt inch in my mint front end was abit hard but after that it was all good
thats how the car looks right now !!! i will keep you guy updated
