You can get the s14 oil pickup which has a bigger mouth, so if the pan gets dented you still get oil. And then there's the b13 oil rail upgrade which let's you run some b13 rails with bigger holes that don't get clogged, and spray more oil on your valvetrain. if your gonna upgrade the oil pan then get the moroso one because the cast shit will just crack the second you hit it.
cool thx for the advice guys yeah i planned on at least getting a new oil pump and a pan is def a good idea. those are some 5zigen rims with 25mm pbm spacers
finally makin progress got my block back today with 87mm cp pistons, eagle h-beam rods, clevite rod/main bearings, arp main, rod, and head studs, and polished crankshaft. head should be done next week.
