Thu Oct 27 2011, 10:31pm
I noticed there is an out of place wire on the first production run of gy6 motor swap harnesses.
Its a one minute fix shown on the following 5 photos:
Follow the grey wire for the controls back to this junction that has 3 black, 1 red, 1 grey wire.
Clip the grey wire as far into the tape as possible & re-tape the others.
Strip the tip of the grey wire you just cut, and attach a female .250 wide 16-14 AWG insulated female crimp on terminal
I'll send you one in the mail if you dont have one handy.
Plug it into the open make terminal on the flasher relay.
connect the other end of the grey wire to the grey wire on the OEM left ruckus controls as directed in the tag.
[ Edited Thu Oct 27 2011, 10:55pm ]
Mon Oct 31 2011, 10:14pm
We are working on a bolt on rear frame / lowered seat / entended motor mount combo, and also a gy6 version of our exhaust if anyone is interested I'll post up pricing and availability when we finalize the welding fixtures, and go into production later.
[ Edited Mon Oct 31 2011, 10:18pm ]
Sun Nov 13 2011, 02:55am
Drum brake hub adapter for GY6 motor and Golf Cart Wheels or ATV wheels. $150
Dual Pattern, 4 lug 4 inch lug spacing, four 12mm x 1.25 thread studs, for use with golf cart wheels OR 4x110 ATV pattern available with stainless 10mm1.5thread bolts and aluminum washers & 4x4 studs pressed out for $20 more. For use with wheels measuring 3 inch back spacing and 4 or 5 inch front spacing 10 or 12 inch dimeter is OK.
Shown below with 4x4 studs left in.
Shown below with 4x4 studs pressed out and mounted to 4x110 wheel with stainless and aluminum hardware.
If you want to knock out the 4x4 studs out yourself without a press, wrap a sledge in lots of tape to protect surface after the stud pops out.
4x110mm hardware: Stainless button head 10mm 1.5thread bolts and aluminum washers to protect your ATV wheel.
2mm stackable positive offset spacer now available for $10ea.
[ Edited Sun Nov 13 2011, 03:09am ]
Sun Nov 13 2011, 03:50am
Spline drive lug nut package for GY6HUB & 4x4 Golf Cart wheels $35
Includes 4 steel alloy spline drive nuts with Gold plated finish, and one key.
[ Edited Sun Nov 13 2011, 03:50am ]
Wed Nov 16 2011, 05:42pm
dam dan you have been keepin martin behind the torch havent you. i miss creating. everything looks super top quality as always and martins welds look better than ever!
Thu Nov 17 2011, 12:30am
we stay busy.
thanks man.
Thu Nov 17 2011, 12:54am
some frame accessories, dirt bike shock mount and LED tail light mount.
Thu Nov 17 2011, 01:19am
Thu Nov 17 2011, 08:58pm
headers just came in for the GET 50cc motor, so the complete system is ready to go!
You can see the spring tool thats included with the exhaust system shown here with stainless parts photos.
[ Edited Thu Nov 17 2011, 09:01pm ]
Wed Jan 04 2012, 02:08am
Revised the frame jig to have the motor mounted for use with the dorby mesh love 12x8 wheel.
So if you like this style, this frame can now be made to order with the correct motor mounts for perfect bolt-it-on-and-ride alignment using the MAX gy6 4x4 bolt pattern hub and dorby 2 piece wheel.
Laser aligned to the new offset which is 10mm off the normal 3+5 offset because of the 2 piece design:
Welding the new setting in place:
Modded customers kickstand:
Added tail light mounting surface for chrome glow flexible LED strip:
[ Edited Wed Jan 04 2012, 02:17am ]
