This answered all my questions since i also have a GT2871R and was confused on if i should get the Flex Cobra with the divider or not ...i was searching Zilvia and didn't see anyone bring this up about the GT2871R and the divider, maybe you should post these pics on there I'm sure this will help some people with the same questions i had. would you happen to have any more detailed pics on this? since i have the turbo already on the car i wanna know how much i need to cut and where.
also any new news on the awesome SR20 Manifold you guys are working on?
OH they're workin on a Manifold? hmmmm....
anyways why dont you just get one with a divider and work your way from there by cutting little by little
*if you have the tomei expreme manifold, that will push the turbo towards the engine and cause this pipe to hit the transmission
Is this valid for the newer version of the downpipe as well, and does it just press against the transmission, or is it simply impossible to mount/use with the Tomei manifold? Also, is it by any chance still possible to have it made without the wideband bung?
I wanted to archive this info from r34SR on zilvia for future reference:
Hey man i just wanted you to know i FINALLy installed this pipe today on my KA24DE with :
ISIS T2 Bottom mount Mani ISIS RS3871 Turbo JGS Rubber motor mounts Xcessive KA lowering mount brackets
With those components the fitment is very good....i absolutely love it so far... i thought you would like to know that i finally installed it and it worked out well for me so far....this way you can tell other customers with confidence that if you use Xcessive lowering mounts...it will bolt up easily on a KA24DE.
Thanks Dan, even though this was over a year ago...i appreciate the tech support....
debut if the new product info channel on you tube: first video of many - Cobra Downpipe! Please subscribe to the you tube chanel for automatic updates on news and new products
