ついに製作開始しました!! Super angle steering knuckle project << Previous thread | Next thread >>
Sat Mar 15 2008, 02:16am
Mmmmm Tasty Teaser!
This should eliminate that nasty bumpsteer, steering lock, and wussy drift angle.
[ Edited Sat Mar 15 2008, 02:33am ]
Kevin
Sat Mar 15 2008, 12:31pm
Registered Member #216
Mmmmm Tasty Teaser!
Do you have a release date for this parts??
Kevin..
white lao tzu
Sat Mar 15 2008, 06:07pm
Registered Member #12
that my friend...
is one noble apparatus
Sat Mar 15 2008, 06:42pm
thats noble research to find the correct angle.
Mon Mar 17 2008, 07:42pm
no release date, we have to test them. There is a bit of an issue trying to tighten the bolt in the space provided.
white lao tzu
Mon Mar 17 2008, 07:51pm
ya, thats what i thought when i looked at them in the pic where the tie rod end is in the knuckle add on peice
Fri Mar 28 2008, 12:11am
Parts Shop MAX super angle steering knuckle project is a success!
We made some changes to improve the part.
We widened the space on one side to put a wrench in it and we still opted to cut down the 19mm wrench to get the bolt tightened but who cares about the appearance of our 19mm wrench...
We cut off the factory knuckle bump stop and straightened out the curved section of our part.
We also needed to make a custom bumpstop on the lower arm.
Here are pics of the finished part and installation.
I am really excited about this part, I think this is the most important part for drifting since diffs and coilovers.
Initial tests are flawless.
No interference in the wheel well on the more aggressive hole.
No noticeable heavyness in steering, but its a little quicker.
It's very intuative - you dont have to completely re-learn the car.
No steering lock / bumpsteer.
No problem resetting the toe.
Big improvement of roll center angle in tie rod.
BIG ANGLE!!
Track testing to follow this weekend.
[ Edited Fri Mar 28 2008, 12:30am ]
Fri Mar 28 2008, 06:05am
100 degrees of angle
Kevin
Fri Mar 28 2008, 12:38pm
Does you will sell them??? If yes I'm really interested. Do you have an aprox price for them????
Thanks a lot!
Kevin..
Fri Mar 28 2008, 06:30pm
We will wait to track test in USA and Japan to finalize the specifications. I will post price and availability when I know.
