I have PSM solid riser, nismo motor and trans mounts, and just installed a DSS driveshaft.
The first thing I noticed is that the DSS driveshaft's u-joints are much larger than stock. So, when installed the u-joints were rubbing on the e-brake clip.
Because of this I was forced to cut the clip. NOW, the driver side cable started hanging too low and the driveshaft started eating away at it.
I decided to pull the cable down temporarily so it wouldn't hit the u-joint and instead rub lightly against the center of the driveshaft.
What are my options to fix this? I want keep the cable held up so it won't hit the u-joints. I don't think I can install any kind of clip there though because the gas tank is on the other side I believe? Anyone have any ideas?
Can the whole e-brake cable assembly be relocated?
