ok so these are super awesome! my car felt really good at top drift this weekend. 2 events ago i broke my drivers side axle (twice), so two of em in one event this event i didnt even break a boot because the max subframe risers help with the axle angle as you can see in the photo. they also help with suspension geometry as you can see in the photo as well if you look at my LCA and stuff. some other cool things that you wouldnt think of till they are on- they allow you to make your exhaust higher by the diff which if youre low is a very weak point on the exhaust. also, it physically makes your subframe higher in your car, which helps for bottoming out ur subframe. ive cracked my subframe twice before so this is a major issue and a good thing to help.
one thing that wasnt expected is it changed my wheel fitment, since the LCA is so angled up, naturally when you lessen that angle it pushed the wheel out, about 5mm on my setup.
overall these are super awesome, install is pretty easy just takes a few hours even if you dont have crazy tools/shop. do it!
