Go to page   <<
danegerous
Tue Nov 25 2008, 04:20am
Registered Member #52
Now I understand what you're saying red rabbit, there is definitly some tracking but thats just the nature of the suspension geometry being changed by a significant drop. my jic's did the same thing, if you caught one of the reflectors in the middle of the road it'd jerk the wheel that direction if you weren't gripping the steering wheel.
red_rabbit86
Sun Dec 28 2008, 10:18am
Registered Member #102
just woundering how many ftlbs do you guys torq your camber/caster plate on?
Mon Dec 29 2008, 08:52pm
Just hand tight, so it cant come loose.
red_rabbit86
Sun Feb 15 2009, 06:46am
just woundering are the bushings in the top hats suppose to move easy?
Mon Feb 16 2009, 08:31pm
no, thats why everything else needs to be tight so it dont turn before the stiff pillow ball.
red_rabbit86
Tue Feb 17 2009, 01:19am
yeah it doesnt it was just hella cold last night below freezing so i think my hands didnt want to work or something but yeah they are good a bit tight but good.
red_rabbit86
Wed Feb 18 2009, 11:05pm
hey i got the 6k springs on the car and after last night i like them i will post pics when i get the chance.
Tue Oct 02 2012, 09:33pm
FC coilover lower mounts and the front knuckle install advice:
in order to install and use the slotted hole setup on the FC lower mounts to adjust KPI and Camber, grind this bump on the knuckle.
[ Edited Tue Oct 02 2012, 09:34pm ]
SuperWOW
Tue Oct 30 2012, 12:56am
Registered Member #3082
I know with Tein coilovers the locking collar is torqued to 100 ft lbs in the front and 50 ft lbs in the rear. I did not know this initially and the collars would come loose every few months. After finally torquing everything to spec there were no issues at all.
I have worked with the PBM coilovers numerous times and have found that using the spanner wrenches with some 1/2" deep sockets with 6 inch extensions make for great final tightening tools.
Maybe some longer spanner wrenches or spanner wrenches that have squares machined out of them for 3/8" ratchets or break bars may be a good idea. Otherwise you can always tap the spanner wrench with a hammer to lock down the adjustment.
Either way, this is a great thread to have!
Go to page   <<
