lowest genesis ever? Springs have not sagged yet and its tucking half the tire. At this height the factory toe rod is capable of zero toe and the camber bolt maxes out at 2 degrees.
Maybe you cant tell by this shot but the wheel travel shoots the wheel back in this car so an adjustable traction rod is defenately needed to keep the wheel centered in the wheel well.
new front lower mount integrates brakeline bracket and swaybar mount
New rear upper pillowball mount design helps lower the car
&heightAll five of the rear multilink parts are designed and prototypes are finished. Subframe solid risers too. While we had the subframe out we blinged it with orange metllic and gold pearl paint.
everything was taken out of the car for a measuring session
kaaz 2 way diff installed
we cut and pryed out the OEM subframe bushings to develop solid subframe risers
we cut down the bushing sleeve as far as we can with the air saw and then pry the rest with a screwdriver
We cut this angle on the subframe RUCA tab because the axle hits it when the car is super low
I wanted to show this picture of my bent subframe lower control arm structure because all it took was a speedbump to bend this. You can see that it bent good enough to chip the paint on the stress points. I can just imagine how F'd up this would be if I dirt drop a wheel on the track at speed, so this is all the more reason that the subframe riser is critical on this car besides the geometry and getting rid of the rubber.
Combines a 15mm bolt on spacer with long studs and three slip on spacers 3mm, 5mm, and 7mm for dialing in the wheel fitment perfectly in 14 combinations up to 30mm wide
Precision machined - Looks fantastic!
Special stud heads with two ears are used as a backup incase the splines ever slip
slimline nuts maximize the amount of aluminum under each nut and also clear the hole for stacking the slip ons
...and the parts removed from the front for a measuring session We will also make tie rods, tie rod angle spacers, bolt on super steering angle knuckle kit, tension rod and front lower control arms
revised toe rod shots showing chromoly taper rod installed, and SFR installation:
Finished Sub Frame Solid Riser prototypes
These are a precision fit but since the subframe has a slight taper, and get bent out of round when removing OEM bushings, we use epoxy to make up for those little inconsistencies. Sand inside subframe for adhesion.
and outside of the subframe solid risers
Mix Epoxy
Install SFR's into subframe cups from the bottom and wipe off excess with wax and grease remover or other solvent (top side view)
Bottom side of subframe view
When you first lift the subframe into place just do it enough to get some threads on
VERY VERY IMPORTANT - you need to cut the front two bolts so that the shank and threads are 4" long. (without the bolt head) cut with a hacksaw or cutoff wheel (preferable). If you dont cut them the tip will bottom out in the car's metal and strip the threads. (arent you glad you read this first?)
tighten each corner little by little allowing the subframe to go up flat.
You dont have to tap this lip up because the RUCA clears even when the shock hits bumpstop but we did anyhow for good measure
I took this picture to show how the driveshaft has perfect alignment with the diff.
We modded the subframe exhaust mount because the car still has factory exhaust but for those of you with aftermarket exhaust, one of the points of raising the subframe is that you get better exhaust to ground clearance (in addition to better roll center geometry).
This toe rod bracket needs to be cut if you are going to be a super lowrider
