Sat Jul 31 2010, 01:03am
Thu Aug 05 2010, 12:55am
revised rear upper control arm and upper traction rod so that you can go deep into the damper bumpstop without rubbing the axle boot.
[ Edited Thu Aug 05 2010, 12:56am ]
Mon Aug 09 2010, 10:27pm
Here is a couple of pix showing how dumped this bad boy can get.
Install shots of our damper adjustment extension.
Subtle smoke treatment of the front lights inner chrome plastics and the outside lens on the rear lights.
Final revision of the rear lower traction rod
A view of all the proto arms mounted together on the car.
Here is all the arms fully compressed. You can see there is still a small clearance for this piece of poster board between the RUCA and frame when the damper is bottomed out all the way.
[ Edited Mon Aug 09 2010, 10:41pm ]
Tue Aug 10 2010, 12:00am
as blingy as these things are on the lift its pretty hard to see them on the street:
[ Edited Tue Aug 10 2010, 12:01am ]
Kevin
Tue Aug 10 2010, 04:14pm
Registered Member #216
are you planning to made some steering angle kit for it ??
Thanks
Kevin..
o.g.darkdrifter
Tue Aug 10 2010, 10:54pm
Registered Member #580
When will this stuff be available for purchase?
Thu Aug 12 2010, 06:56pm
we are totally making a steering angle kit for it.
Were not done designing and testing stuff yet so i cant say when
Tue Aug 17 2010, 12:27am
more wheel spacers and fender rolling/pull
[ Edited Tue Aug 17 2010, 12:32am ]
Sun Feb 20 2011, 08:03pm
so what offset are you at now with the spacers and everything ? i have to say i drove one yesterday and i quite like them. they do handle verry nice also i like the new lock on the ride height part of the coilovers. always seem to have a problem with everything working its self loose.
also last pic on here do i spy a cb650 ?
Mon Feb 21 2011, 01:35am
Damn! you are good,,,that's Dave's toy..its really cool and 2 stroke!
