thanks guys! not much updates, been busy with my cs rc car haha ive been missing my sc300, so i made this to satisfy my feelings.
anyway, about my 1:1 car, i finished all the wiring for under my seat, with the exception of my speaker wires.
then these were finally made: a70 supra solid subframe riser bushings!
installation would have been easy if my subframe wasnt powdercoated, i had to sand the holes and lube it to push in the bushings. it was still snug so i didnt use epoxy. for a regular finished subframe, just epoxy it, and slide it in!
i got everything back together and test drove the car, boy does the solid rear end make a worlds difference, i didnt attach my rear sway bar back on yet, but i was able to get loose petty easily. i still need to adjust my ride height, put back on the rear sway bar, get an alignment, and fix my s2 fenders to accommodate the suspension geometry change.
