rafas13
Fri Dec 21 2012, 08:48pm
Registered Member #717
when will s chassis solid bushing be available again?
Fri Dec 28 2012, 07:57pm
today
Thu Feb 14 2013, 04:20am
oh sweet went on to see when these would be in. and look they are. need them. my bushings are toast.
booey13
Thu Feb 14 2013, 06:43am
Registered Member #704
^that's a post from December. Or are you seeing something that I'm not? They still say out of stock on the product page.
Sun Feb 17 2013, 04:49am
nope im stupid got excited and posted that cuz my shit tore up the other night. soo now im on home made delrin inserts till these are back in stock. ugh
booey13
Mon Feb 18 2013, 04:20pm
Bummer man. If you can't wait someone has a new set for sale on zilvia.
Mon Feb 18 2013, 09:15pm
I just pulled the subframe last night. Going to clean it up and prep for all n ew shit. Dirt drop in az resulted in broken lca.
rusty s13
Thu Sep 05 2013, 06:15pm
Registered Member #3193
Ok so I am curious about something. Why do the s chassis risers have the big countersink in them instead of just being flat like the genesis ones. I had a machinist friend cut me some nice big washers to use because using the factory hardware required spacing the nut out with washers and I just dont want to do that. is there something I am missing?
Thu Sep 05 2013, 06:20pm
Usually we put the OEM large washer back on there, or in the case of S15 its the OEM subframe brace that has two circular mounts that fits right up in that space.
rusty s13
Thu Sep 05 2013, 06:45pm
Ya I put the oem large washer back on and it actually hit the taper on the stud before it came up tight on the nut and i also ran out of threads on the nut. maybe a slight difference in the studs? also do you see any issues with using a large washer over the top of the bushing. I had 2.5 inch od 1/4 thick washers made up just to kinda clean it up.
