87 supra, 7mgte, r154, sport package (lsd, no tems, abs) 61k miles. Full build up for general fun and drifting.
I started this build around jan '11, so most of this is back tracking. engine: block has been decked and honed head has been decked, lapped, and given new valve stem seals HKS 1.2mm headgasket ARP studs ACL main, rod, thrust bearings NPR piston rings 57 trim ct26 Polished compressor housing, ceramic coated turbine housing FMIC & aluminum piping Synapse Synchronic BOV Synapse anti stall kit NGK ignition wires Denso MDL560P injectors EV1 injector pigtails Denso 195130-1270 280lph fuel pump lexus 1uzfe maf yada, yada, yada
EV1 pigtails being soldered in and fuel upgrades
got the original mounts welded by martin, dont see the point in buying solid ones when i could just do this.
currently on hold:
rebuilt the transmission before it went in got a bunch of nice goodies while i was at it. action stage 3 6 puck clutch disk & pressure plate full length SS clutch line Maxgrip lsd kit 4.30 lsd
rebuilt my work equips and ended up with 18x10.5-12 18x11.5-26 225/40/18 f 255/35/18 r
suspension components: part shop max competition coilovers battle version rear camber arms battle version rear traction arms shortened toe arms SuperNow outer tie rod ends & steering rack spacers Power Slot rotors front & rear EBC red suff brake pads
dropped the rear end so doing a couple of things solid rear subframe risers shaved unnecessary brackets and studs, not sure if i want/need to brace it.
lowness
exterior: s2 authentic rear fenders part shop max hood risers jdm kouki tail lights jdm sidemarkers euro signals kouki side mirrors kouki front bumper
dude knoch that sub frame where the axle is hitting and just weld some plate around it so it dont tear. cant beleive that this thing is as low as pbm coils can go, never seen that before ever and for that i apluad you, thing needs like some bn stlye kit and would win so hard its retarded. ps is marty going to do some kako knucles for ya and any rolling shots ?
Looks good man, love the wheels/stance direction your going.
deolio wrote ...
rad!
Fish wrote ...
Beast!
thank you, thank you, thank you.
Hollywood wrote ...
yeah i was thinking about doing that. notching it and then welded a plate to cover the hole. but i figured its useless since im already rasing the subframe about 15mm which is more than enough to clear, even if bottomed out. i wish BN made shit for this car. hell, atleast someone. current aero for this car is a joke. funny you ask about the kako knuckles. i just got an extra pair to be worked on:
other than that, not much new from yesterday and today... drilled another set of holes in my stock sway bars for adjustability, probably only be putting the rear as stiffer since it understeers as it is for me. then dropped off the rear subframe with the sway bars for powdercoating.
finished the LSD
energy suspension sway bar bushings. NOTE* energy suspensions database for my car is incorrect. factory sway bar diameters: F - 27.2mm R - 21mm
energy suspension database/catalog: F - 27mm (8.5133) R - 23mm (8.5134)
Though the front is .2mm small, it still works. only issued i encountered with it is that the overall height was 2.5mm too tall so i trimmed the bottom. rears i had to return and buy the universal kit, product number 9.5125. i bought these from: http://www.energysuspensionparts.com/ The whole hassle with their database being wrong and for me to be the one losing the money on shipping is really unsatisfactory customer service, i think.
Fitment looks tough! Good to see someone putting in work on one of these. 7Mgte.... sketchy haha. But the R154 looks good..... sell it to me please.
Been running the 7m pretty hard for about 8 months now and its been fine. knock on wood* i still need to get it tuned.
gaki no tsukai wrote ...
Sick build man. how was it building your lsd? Do you reccomend ther wier max grip kit? Im am looking to build mines before the season starts this year
installation was pretty straight forward. so far i just got the unit back together. On the market right now for some oil, ill let you know how it is after i get my car back together. still waiting on some subframe risers and then i can put the rear end back up so i can drive this thing.
