hey man saw that you posted the new parts...pumped to order them on my next pay check. also i forgot to ask...are you guys making outer tie rods too? i see you guys made rack spacers.
Ah okay....So a lot of people switch to special bearing outer tie rods. Saying that it will help get a little more angle and last longer then stock. What is your take on this? Is it worth switching over or is OEM fine.
last longer...typically not because the aftermarket ones are the high misalignment type which has a large surface area to gather dirt and then they wear themselves out faster versus the OEM ones that are lubricated and closed to the elements with a boot which lasts longer.
